What versions of DataMiner do we need to use to work with ADFS + SAML for https and Cube connections
Solved391 views5th January 2026
Jaroslaw Burtny [DevOps Member]756 2nd December 2025 0 Comments
Hi All.
What versions of DataMiner do we need to use to work with ADFS + SAML for https connections and on which version does it work with the Cube client?
Big thanks for naswer.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th January 2026
Christine Kapembe [SLC] [DevOps Advocate]1.01K Posted 23rd December 2025 0 Comments
A ticket was raised for this enquiry, and guidance on the correct configuration was provided.
If you would like to configure SAML with ADFS, please refer to the following guide:
Configuring SAML with Microsoft Entra ID as identity provider | DataMiner Docs
You will need to configure the corresponding settings on ADFS as outlined in the documentation.
SSO is now working for both Cube and web apps.
Bert Vandenberghe [SLC] [DevOps Enabler]9.68K Posted 2nd December 2025 0 Comments
Hi Jarek,
I believe any currently supported version of DataMiner supports SAML nowadays. E.g. I do find a 'since version 10.1.5' on this page: Configuring SAML with Microsoft Entra ID as identity provider | DataMiner Docs.
Cube should also support it since that same version, so any supported version.
That being said, the more recent the version is, the better. There have been several improvements made to SAML so I would personally recommend at least 10.4.
Bert
Bert Vandenberghe [SLC] [DevOps Enabler] Answered question 2nd December 2025
