What is the right driver to use for controlling Elemental encoders L843AE and L842AE?
Solved1.68K views19th July 2023
Dominik Kosteletzky [DevOps Advocate]773 18th December 2020 0 Comments
I see...
Elemental Conductor
Elemental Live
Elemental Conductor - Node
..could be used
Regards
Stacey Van Colen [SLC] [DevOps Member]2.75K Posted 21st December 2020 5 Comments
Hello Dominik,
Normally the Elemental Live should be used if you want to control Elemental Encoders directly.
The Elemental Conductor is:
AWS Elemental Conductor is an on-premises management system for AWS Elemental Live encoder nodes.
So the driver we have for the Conductor is then to control that Management system.
If you would have such a Elemental Encoder device available, and would like to test out the Elemental Live driver, you can always ask your Account Manager for a trial.
Dominik Kosteletzky [DevOps Advocate] commented 22nd December 2020
Hi Stacey,
thanks a lot for the answer!
Regards
Stacey Van Colen [SLC] [DevOps Member] commented 22nd December 2020
You are very welcome Dominik.
If you have any more questions, feel free to post them here on the dojo platform.
If feasible, could you flag the response to your question as the answer that resolved your question? It then will set your question as resolved.
S R K Chowdary Alla commented 3rd January 2021
Dear stacey,
Like the WebGUI, Is there any option to edit/change the Output/Stream name on Elemental Encoder?
Thanks.
pramod Gupta [SLC] [DevOps Member] commented 11th January 2021
Thanks Chowdary, we will get back to you soon, (either via email or here in community).
Stacey Van Colen [SLC] [DevOps Member] commented 11th January 2021
Hello Chowdary,
Currently the functionality to easily modify this is not yet in the driver, but we can extend the driver to include this functionality.
We currently do have the option to send a complete event.xml file which would contain the entire structure of the Live Event. And in this event.xml file you could modify the Output/stream names.
