What is the maximum recommended latency for remote DMA-DMP Communication
Solved2.08K views14th July 2023communication DMP
Jarno Lernou [SLC] [DevOps Enabler]6.08K 16th May 2022 0 Comments
Hi all,
Are there any recommendations on the network latency between the central DataMiner agent and the DataMiner probe?
Thanks!
Rene De Posada [SLC] [DevOps Advocate]1.94K Posted 21st May 2022 1 Comment
Jarno,
I don’t see any reason to drift away from the general recommendations of 30-50 ms (https://community.dataminer.services/dataminer-compute-requirements/).
Thank you,
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 14th July 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 14th July 2023
Note that the compute requirements have been moved to https://docs.dataminer.services/user-guide/Reference/DataMiner_Compute_Requirements.html
