What happens to a process when the node fails and failover takes over?
Solved2.22K views19th October 2023Failover process automation
bruno santos [SLC] [DevOps Advocate]1.30K 9th June 2023 0 Comments
In a case like MAM – Media Asset Orchestration, if the main node fails while the process is running what happens with that process?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th October 2023
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 19th October 2023 0 Comments
Bruno,
When standby node becomes online, the process will still be running.
In case the process was busy executing script to initiate actions such as the conversion of a file, then the processing of that asset could fail.
It all depends on how the application has been implemented. There are definitely options to support recovery in such a situation.
Koen Annys [SLC] [DevOps Advocate]144 Posted 4th July 2023 1 Comment
Can you clarify more what you mean with “the process” ?
In general , when a DataMiner system has a failover event, it means the failover agent takes over and all important processes will now be handled by that new system. This means a process on the earlier active agent will now be stopped. This should not be a problem since data is synced with the failover system but edge cases could occur. Note not all DataMiner system processes are stopped on the failover agent when its marked as offline since it still needs to be able to sync and receive indication it should go online etc.
bruno santos [SLC] [DevOps Advocate] Posted new comment 5th July 2023
bruno santos [SLC] [DevOps Advocate] commented 5th July 2023
Hi Koen, by Process I’m referring to the execution of a process in Process Automation failing between two activities – https://docs.dataminer.services/user-guide/Standard_Apps/PA/PA_Concepts.html.
