What commands are required for Nexus 93180YC to integrate with Dataminer?
Solved2.76K views19th January 2024
Motoki Orikasa [DevOps Member]86 24th October 2023 2 Comments
Hello All,
I'm trying to create a dashboard using a Nexus 93180.
Please let me know what commands I need on the Nexus93180 side to do this.
"feature nxapi" could be adapted, others want to know.
Cheers,
Motoki
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th January 2024
Ive Herreman [SLC] [DevOps Enabler] commented 24th October 2023
Hi Motoki,
Which driver are you using to integrate the Cisco Nexus into dataminer?
Are you using the SNMP/API based one, or the OpenConfig/GNMI based one?
Motoki Orikasa [DevOps Member] commented 24th October 2023
Hi Ive,
I’m using the “Cisco Nexus” Driver!
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 24th October 2023 12 Comments
Hi Motoki,
Next to the 'feature nxapi' command, you'll also need to configure SNMP.
This can be done with the sample commands below:
snmp-server community public RO
snmp-server community private RW
Hi Ive,
OK, it’s done!
Please check the show run snmp.
OTC-Nexus93180YC(config)# sh run snmp
!Command: show running-config snmp
!Running configuration last done at: Tue Oct 24 21:44:05 2023
!Time: Tue Oct 24 21:45:21 2023
version 10.3(1) Bios:version 05.47
snmp-server user admin network-admin auth md5 167B2E75E5E9FC3657ED2284586398F6026D priv aes-128 00743177CB99D3186BF94CD9566C9EE0463F localizedV2key
snmp-server host 192.168.102.230 traps version 2c public
snmp-server host 192.168.102.29 traps version 2c public
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
snmp-server enable traps ospf
snmp-server enable traps callhome event-notify
snmp-server enable traps callhome smtp-send-fail
snmp-server enable traps cfs state-change-notif
snmp-server enable traps cfs merge-failure
snmp-server enable traps aaa server-state-change
snmp-server enable traps feature-control FeatureOpStatusChange
snmp-server enable traps sysmgr cseFailSwCoreNotifyExtended
snmp-server enable traps config ccmCLIRunningConfigChanged
snmp-server enable traps snmp authentication
snmp-server enable traps link cisco-xcvr-mon-status-chg
snmp-server enable traps vtp notifs
snmp-server enable traps vtp vlancreate
snmp-server enable traps vtp vlandelete
snmp-server enable traps bridge newroot
snmp-server enable traps bridge topologychange
snmp-server enable traps stpx inconsistency
snmp-server enable traps stpx root-inconsistency
snmp-server enable traps stpx loop-inconsistency
snmp-server enable traps system Clock-change-notification
snmp-server enable traps feature-control ciscoFeatOpStatusChange
snmp-server enable traps mmode cseNormalModeChangeNotify
snmp-server enable traps mmode cseMaintModeChangeNotify
snmp-server enable traps syslog message-generated
snmp-server enable traps lldp lldpRemTablesChange
snmp-server community public group network-operator
snmp-server community private group network-admin
Hi Motoki,
This looks good.
Your dataminer element should work with this config.
Hi Ive,
Thanks for advice!
do you know the dashboard also?
Hi Motoki,
I’m not sure. Which dashboard are you referring to?
Hi Ive,
it’s a dashboard that visually shows the linkup/down interface or PTP something status of NexusSW.
Show 7 more comments
