Weird problem with C# Automation scripts and validation
Solved1.40K views18th May 2026Automation script validation
Chris Glover [DevOps Advocate]2.25K 18th May 2026 0 Comments
I've created an automation script in DIS, which I've published to a DMA, this script fails validation, but Visual Studio is happy. Validation is failing on the first line of the script
using System;
I don't understand why it is failing there. We have lots of scripts that start way. I tried to create a new script directly in the Cube editor, containing only the using System; with nothing else and that also fails validation.
As you can see, there really is nothing in this script, so I don't understand why validation is failing at this point. Any help will be greatly appreciated.
If it's of relevance, the machine running Cube is running Server 2025
Chris Glover [DevOps Advocate] Selected answer as best 18th May 2026
Pedro Debevere [SLC] [DevOps Enabler]3.52K Posted 18th May 2026 0 Comments
Hi Chris,
When creating the script, SLAutomation will look for a string "class Script" in the code. If that is not present, it will take the provided content and put it inside such a class (for more info, see Script class).
This behavior is done unless the script is marked to be compiled as a library.
