Web Interface is showing nothing in cube.
Solved3.30K views18th July 2023web interface
Pascal Puzio [DevOps Advocate]20 11th October 2021 0 Comments
Hi all,
When I try to see the Web Interface of different elements, the pages showing nothing.
When my colleague does the same on his cube, the web page will be displayed as expect.
Is there a setting in my cube/account which prevent me to see the Web Interface?
Thanks.
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 12th October 2021 0 Comments
Hi Pascal,
I checked by disabling my rights to access the web interfaces, but then I see the following message on the page in DataMiner, so I don't think it is related to your rights.
As you indicated that your colleague can see the web interface on the same machine I would suggest checking what you see in the following folder for you and your colleague: %localappdata%\Skyline\DataMiner\DataMinerCube\CefSharp
That folder contains the chromium plugin (which is normally used to visualize the web pages).
Michiel Saelen [SLC] [DevOps Advocate] Edited answer 12th October 2021
