Web Interface is showing nothing in cube.
Solved3.21K views18th July 2023web interface
Pascal Puzio [DevOps Advocate]20 11th October 2021 0 Comments
Hi all,
When I try to see the Web Interface of different elements, the pages showing nothing.
When my colleague does the same on his cube, the web page will be displayed as expect.
Is there a setting in my cube/account which prevent me to see the Web Interface?
Thanks.
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 12th October 2021 1 Comment
Hi Pascal, can you check if the browser engine settings are identical? You can find these in System Center/System settings/plugins.
If it is a specific protocol for which you have issues, you can also add protocol-specific settings from this window, e.g. for web interfaces of older devices that are only supported by Internet explorer.
Michiel Vanthuyne [SLC] [DevOps Advocate] Edited answer 12th October 2021
Pascal Puzio commented 12th October 2021
Thanks Michiel,
I found this solution already here on the Dojo, and tried it, but it did not work.
Further to mention, is that my colleagues don’t have the problem to open the web interfaces on the elements.
Also tried on the same server, if my colleague log in, then it works under his account, and when I log in, then it did not work.
It looks that there is a maybe viewing right issue?
