WEB dashboards unavailable locally in Cube
Solved732 views3rd August 2026
Miloš Sedláček [DevOps Advocate]832 23rd July 2026 0 Comments
Hi Community,
we include WEB dashboards as reports to emails regularly sent to monitor performance of our system.
The dashboard could be selected and attached to a report when connected to Cube via dataminer.services
On the other side, the dashboard is missing in the list when connected to Cube locally (accessing by IP address on the LAN)
As you may see, all the WEB dashboard seem to be missing from the list. However I can access the dashboards locally in WEB browser.
I'm connected to Cube using the same user in both cases.
We have self hosted DMS with local cassandra/opensearch.
Miloš Sedláček [DevOps Advocate] Selected answer as best 3rd August 2026
Seppe Dejonckheere [SLC] [DevOps Enabler]3.05K Posted 23rd July 2026 1 Comment
Hi Miloš,
My guess is that Cube fails to fetch the available Dashboards because it doens't have a valid certificate configured. Do you see any kind of certificate warning when opening a dashboard in your browser?
Miloš Sedláček [DevOps Advocate] commented 3rd August 2026
Hi Seppe, indeed, I had to import the DMA certificate onto the local machine where I was connecting to Cube from.
