VLC component not correctly displayed – Visio missing?
Solved1.70K views1st April 2022Visio visio; thumbnail
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.28K 31st January 2022 0 Comments
We are using DataMiner cube app to view a certain videostream, and with the new client, it is no longer visible. In fact, we do not have the option to download the visio too, please check the below image :
As you can see, right clicking on the overview does not provide the option to download the visio. These are the version details :
Server version : 10.1.0.0-11229 CU10
Client version : 10.1.2046.9952-af35e33c
Launcher version : 10.1.2138.1350-ab664991
Previously, we used
Client version               : 10.0.1947.6954
and the videostream worked.
Is there a workaround/solution for this ? TIA 🙂
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 1st April 2022
Jarno Lernou [SLC] [DevOps Enabler]5.81K Posted 31st January 2022 1 Comment
Hi Arun,
Maybe you can find the answer you're looking for in other questions on Dojo:
  • VLC plugin in the future DataMiner versions - DataMiner Dojo
  • VLC Visio Links in dataminer X - DataMiner Dojo
To edit or download the Visio, maybe you could use the hamburger menu of your card?
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 31st January 2022
Hi Jarno,
Thanks for the suggestion but the UseIE option does not work. I need to install VLC media player on every possible client; only then this is working.
