Visual studio new Automation Script Project Template
Solved1.78K views26th June 2025DIS Automation From Scratch
Michael Loidolt [DevOps Member]97 28th February 2025 0 Comments
Hello
Since updating to the new DIS version, I have no longer been able to create an automation from scratch. The references in the Solution Explorer no longer match. The structure no longer fits either. Has anything changed ? Maybe I' m making a mistake too, but it' s always been pretty ease to create on automation from scratch !!
Davor Joleski [DevOps Enabler]743 Posted 28th February 2025 0 Comments
Michael hello i had same problem u can see my question task i place link how i fixed this after an update i hope will help you like me
Creating automation script Problem SDK
Davor Joleski [DevOps Enabler] Answered question 28th February 2025
