Visual Overview – Why are my DCF connections not visible when embedding
Solved2.19K views21st November 2022DCF Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.01K 18th June 2021 0 Comments
I have a view on which a part of the Visual Overview is linked to another page. When this page is visible, the DCF connections on my switches are also visible
However, when I add option hidden on that page, the connection lines are no longer visible. Why is that?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 21st November 2022
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 21st November 2022 2 Comments
This looks like a bug, we have a task on the roadmap to provide a fix for this issue
if you want an update or have any questions don’t hesitate to contact techsupport@skyline.be
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Edited comment 12th August 2024
Jens Vandewalle [SLC] [DevOps Advocate] commented 21st November 2022
Thank you Marlies for the follow up!
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 12th August 2024
Has been resolved as of DataMiner 10.3 (CU17), 10.4 (CU5) and 10.4.8.
