Visual Overview – Shape position in Cube not the same as in Visio
Solved1.29K views18th July 2023Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 5th November 2021 0 Comments
I noticed that the position of my shape in Cube isn’t the same as defined in Visio. I’m just using text with a button executing an Automation Script.
Visio
Cube
Am I doing something wrong?
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 5th November 2021 0 Comments
Hi Jens,
I believe the line spacing between lines of text is different between both screen grabs. The button is positioned absolutely to its container causing the misalignment.
While looking at Visio, i see the default line spacing is set to 120%. Perhaps reducing this to 100% will make it sync correctly.
Feel free to create a NSF for this, so we read out the line spacing from the Visio file and apply it on the Visual Overview.
