Visual Overview – Is it possible to create a matrix shape by using the source and destination tables
Solved2.53K views25th January 2021Matrix Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 25th January 2021 0 Comments
I found that it's possible to link a shape to a matrix parameter where using the matrix component is mandatory. Is it possible to have more or less the same behavior in Visual Overview by only using the source and destination tables?
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 25th January 2021
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 25th January 2021 0 Comments
The Visual Overview matrix shape will only work for a matrix parameter. This includes support for a matrix parameter that uses source-destination tables.
Using these tables separately without a matrix parameter will not work.
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 25th January 2021
