Visio/Dataminer Connector style guide
Solved766 views11th September 2025
James Barrett [DevOps Enabler]45 10th April 2025 2 Comments
Hello Dataminer community,
First time poster here...
Is there a reason why my connector styles aren't translating directly from Visio to Dataminer?
The Visio connectors snap and display dynamically, where are the Dataminer representation are just straight lines to and from each connecting point.
Is there a recommended style in order to properly display this visualisation?
(Ignore the large blocks of black - i'm redacting sensitive IP information)
Thanks all,
James
(Visio display Below)
(Dataminer display below)
Toon Casteele [SLC] [DevOps Enabler] commented 10th April 2025
Welcome to the Dojo James! Could you share some more info about your setup? Is this a setup that uses DCF, what options do you have configured on your shapes (such as the Connection shape), etc. I have some ideas as to what is causing this, but that will make it easier to narrow it down.
James Barrett [DevOps Enabler] commented 10th April 2025
Hello Toon,
Thank you for the response.
There is no DCF utilized in this diagram. The connection shape is the Curved Connector without any shape data.
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 10th April 2025 3 Comments
Visual Overview does not support all ways of drawing shapes and lines that Visio itself does. I suggest working with straight lines as these are definitely supported.
Thank you for the support.
Steve Purcell [SLC] [DevOps Advocate] commented 10th April 2025
James, you could also take a look at the Node Edge Graph component of the Dashboard interface – https://community.dataminer.services/use-case/node-edge-graph/ This might give you the curved structure you are looking for automatically. Then if needed in Visio, you can just reference the HTML page.
James Barrett [DevOps Enabler] commented 11th April 2025
Thank you for the suggestion Steve, i'll explore this option.
