View or Element with the same Name
Solved2.42K views11th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 5th November 2020 0 Comments
I want to create an element or view with the same name for management.
Is there a way to allow Surveyor to allow duplicate names?
Lander Vanhaverbeke [SLC] [DevOps Member]1.01K Posted 5th November 2020 0 Comments
You can create an element and a view with the same name. You can’t create multiple elements or multiple views with the same name. They have to be unique so they can be identified in flat lists.
I suggest to add a prefix or suffix to the name, for example “MyDevice – Management” and “MyDevice – Polling”.
Miguel Obregon [SLC] [DevOps Catalyst]23.66K Posted 5th November 2020 0 Comments
Hi Yuki,
I am afraid that this is not possible at the moment. DataMiner does not allow to create two elements (or views) with the same name.
However, there is a way to have two elements with the same name in the context of a service layer. When creating a service, you can define an alias to the element included in the service. For example:
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 5th November 2020
