View Card > Elements > Save Column order?
Solved1.38K views19th July 2023adl2099 default columns savelayout View Card
Alberto De Luca [DevOps Enabler]5.36K 11th July 2023 0 Comments
Hi, dojo – any workaround available to avoid manual reordering of columns in view cards?
This is a follow up from this older question: https://community.dataminer.services/question/any-method-to-define-the-default-column-order-in-the-different-cube-sections/?hilite=save%20columns – where it was confirmed that re-ordering columns has limited support for a “View” card, while a “save layout” option has been implemented for the columns in element tables.
As a consequence, manual reordering needs to happen when quickly opening views to retrieve the global state for many elements:
I think this feature suggestion is still relevant, but any shortcut that can save time, ad-interim, please give me a shout 😉
https://community.dataminer.services/new-feature-suggestions/define-the-default-column-order-for-element-list-in-any-view-card-and-for-the-alarm-console/
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 11th July 2023 0 Comments
Depending on which application and feature set you would wish to use, there are a couple of alternatives. In Visual Overview, you could use the Listview while in Dashboards and Low Code Apps there are also several options.
I hope one of those can help you achieve your goals.
