Using Skyline.DataMiner.Automation inside QActions possible?
Solved2.03K views2nd February 2023Automation QAction Skyline.DataMiner.Automation
Trong Huynh [DevOps Advocate]881 2nd February 2023 1 Comment
Is it possible to use the automation’s engine methods inside a QAction?
I’d like to use some methods (e.g. SendEmail) in the Engine class (part of the Skyline.DataMiner.Automation library).
I have done the followings my QAction:
  1. Installed the Skyline.DataMiner.Dev.Automation NuGet package
  2. Imported the library (using Skyline.DataMiner.Automation;)
  3. Declared the engine object (Engine engine = new Engine();)
  4. Called the method (engine.SendEmail();)
But it failed. Errors in the Element log says:
The type or namespace name ‘Engine’ could not be found (are you missing a using directive or an assembly reference?)
Thanks!
Trong Huynh [DevOps Advocate] Selected answer as best 2nd February 2023
Michiel Oda [SLC] [DevOps Advocate] commented 2nd February 2023
Do note that the Skyline.DataMiner.Dev.Automation package is filtered out by DIS when compiling the protocol as it is not useable.
Laurens Moutton [SLC] [DevOps Enabler]9.61K Posted 2nd February 2023 0 Comments
The automation library is only intended to be used in an automation script. The “engine” object in automation scripts is the connection with the SLAutomation process, similar like the “protocol” object in QActions that is the connection with the SLProtocol process.
The class library consists of 3 parts:
  • Automation: functionality to be used in an automation script
  • Protocol: functionality to be used in a QAction
  • Common: functionality that is independent, these items can be accessed both from an automation script or from a QAction.
I can think of 2 alternatives:
  • Either write an own method in the QAction to send a mail
  • Or launch an automation script from the QAction that will then call the Engine.SendEmail()
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 2nd February 2023 0 Comments
Hi Trong,
This is not possible.
Or you can run an automation script that will send an email from your QAction (see Method ExecuteScript) or you can use some .Net functionality (see post Sending email with attachement from a QAction)
Jens Vandewalle [SLC] [DevOps Advocate] Edited answer 2nd February 2023
