Using Reg Ex in Filters
Solved3.12K views11th July 2023
Ken O'Connor701 25th August 2022 1 Comment
I have alarms comin in with the parameter description containing XXXXXX or YYYYYY
I want to filter these using Reg Ex . I have tried the following:-
^(?!(XXXXXX|YYYYYY))
(XXXXXX|YYYYYY).*\s+\1(\s+|$)
and others..
So Alarm A comes in with the field Parameter.Description = ‘XXXXXX’
then Alarm B comes in with the field Parameter.Description = ‘YYYYYY’
the Alarm C comes in with the field Parameter.Description = ‘ZZZZZZ’
So I want to use a reg ex to filter on the XXXXXX or YYYYYY only.
Ive Herreman [SLC] [DevOps Enabler] commented 25th August 2022
Hi Ken,
Where are you applying the filters?
e.g. a visio, the alarm console, dashboards
Ive Herreman [SLC] [DevOps Enabler]14.80K Posted 25th August 2022 0 Comments
I made a quick test, which seem to do the trick.
Would the configuration as shown below work for you?
This gives me the following output
Tom Waterbley [SLC] [DevOps Enabler]10.36K Posted 25th August 2022 1 Comment
Hi Ken, the quick filter in the alarm console probably doesn’t support regular expressions. However you could create a new tab that only shows alarms that match a regular expressions. See https://docs.dataminer.services/user-guide/Basic_Functionality/Alarms/Working_with_alarms/Working_with_the_Alarm_Console/Applying_alarm_filters_in_the_Alarm_Console.html#alarm-filters-using-regular-expressions.
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 25th August 2022
Tom Waterbley [SLC] [DevOps Enabler] commented 25th August 2022
The regex needs to match the whole string. So maybe try this as filter: .*(XXXXXX|YYYYYY).*
Ken O'Connor701 Posted 25th August 2022 1 Comment
Hi Ive..
In the Alarm Console. Essestially, Parameter Description (by element) Matches regular Expression (XXXXXX|YYYYYY) should work.. tested it with a .NET Reg Ex tester
Ken O'Connor [DevOps Member] Posted new comment 25th August 2022
Ken O'Connor [DevOps Member] commented 25th August 2022
Hi … Thanks for all your inputs. After messing with it, I have worked it out.. Cheers all.
