using Parameter Key in Hyperlink
Solved1.71K views13th July 2023hyperlinks
Jeroen Geldhof [SLC] [DevOps Enabler]5.52K 31st August 2022 1 Comment
I’d like to use the ‘Parameter Key’ alarm property in a Hyperlink in the alarm console.
It’s however not available in the Help.
Is something like this possible?
https://docs.dataminer.services/user-guide/Reference/Skyline_DataMiner_Folder/More_information_on_certain_files_and_folders/Hyperlinks_xml.html#keywords
Marieke Goethals [SLC] [DevOps Catalyst] commented 13th July 2023
As this question has been inactive for a long time, we will now close it. If you want further assistance, feel free to post a new question or contact techsupport@skyline.be.
Jarno Lernou [SLC] [DevOps Enabler]5.96K Posted 31st August 2022 1 Comment
Hi Jeroen, I once stumbled upon the same objective. I was informed that having the table index as part of a keyword is not available. There is a subtle work-around though. Normally you can use the PNAME keyword. In case of a table parameter (cell), it will return [Parameter Description][SPACE][TableIndex].
By using some C# logic, you can simply get the table index from this.
Kind Regards,
Jarno
Jeroen Geldhof [SLC] [DevOps Enabler] commented 31st August 2022
Unfortunately I don’t plan on using an automation script.
I’d like to load a Dashboard and use the key for filter purpose
