Using HTLM and VISIO-View
Solved1.66K views12th September 2023HTML Visio views
Baumgartner Stefan308 11th September 2023 0 Comments
Good afternoon
For management and people with no Dataminer experience, we would like to provide an HTML5 page of Dataminer for overview. The user should be able to click on the Visios and then dive down one level (Dataminer Views).
On the HTML page you cannot click on the Visio view – nothing happened. But with Cube it works.
Is there a limitation from the HTML/dataminer side or have we implemented something badly?
(Browser: Firefox, Connection: http)
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 12th September 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 11th September 2023 0 Comments
Regarding navigation actions, if they function properly in Cube, they should also work seamlessly in the mobile Visual Overview.
However, it’s challenging to provide specific guidance without information about your DataMiner version and access to the Visio file. I recommend sharing your Visio file with us so that we can identify any navigation issues. Please don’t hesitate to reach out to us by sending an email to techsupport@skyline.be, referencing this question, and attaching the Visio file for our review.
