Using GetServicesForFilter WebAPI
Solved1.38K views4th August 2024WebAPI
Bing Herng Chong [SLC] [DevOps Advocate]1.54K 6th November 2023 0 Comments
Hi, I'm helping a user to better clarify the use case of the GetServicesForFilter WebAPI.
There are a number of services that the user has created in Production (in the '000). And each service has a handful of properties. One of the properties is as follows:
Now we would like DataMiner to return the Service whose value for this property is of a particular value:
Using ConnectApp we obtain a GUID, then we send the GetServicesForFilter request following via PostMan:
But we got the following error:
    "Message": "Error trapped: Object reference not set to an instance of an object.",
    "StackTrace": "",
    "ExceptionType": "Skyline.DataMiner.Web.Common.WebApiException"
We need some advice on whether we using this WebAPI call correctly?
Trevor Max [DevOps Member] Answered question 4th August 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 6th November 2023 1 Comment
Hi Bing,
Your syntax is correct. We're looking at a software issue here. We have added a task to our backlog and aim to resolve this as soon as possible. I'll post an update here once it has been fixed.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th November 2023
Bing Herng Chong [SLC] [DevOps Advocate] commented 6th November 2023
Thanks for looking into this query Sebastiaan.
