Using dashboard/LCA to monitor 24/7 and avoid automatic disconnection
Solved1.09K views22nd November 2024Dashboards disconnection LCA
Miguel Barquet [SLC] [DevOps Advocate]1.92K 17th June 2024 0 Comments
Operational teams use DataMiner to monitor their systems 24/7. Some keep a “dashboard” open in their monitor wall to detect any problem quickly.
In Cube, it is possible to disable the session automatic disconnect as follows.
How can we achieve the same for dashboards and LCAs? Is there a user setting that controls automatic disconnects?
Thanks
Miguel Barquet [SLC] [DevOps Advocate] Selected answer as best 22nd November 2024
Gerwin van der Kamp [DevOps Advocate]3.71K Posted 18th June 2024 1 Comment
Hi Miquel,
I’ve ran into the same issue and raised a ticket(DCP154739) ,
there is a workaround:
Workaround
Recycling can be minimized by tweaking the IIS recycle schedule: https://docs.microsoft.com/en-us/iis/configuration/system.applicationhost/applicationpools/add/recycling/
However, since this is a mandatory mechanism, it will need to happen at some point (requiring user input).
At the moment, the workaround that is currently being used is a “Tab Auto Refresher” plugin for Chrome.
But i havent seen this fixed in at least 10.4.3
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 20th September 2024
You’re absolutely right. Recycling is inherently part of the web server. We have a plan for how to address this in the future, but since it involves significant changes, it’s being postponed for now.
