Using custom dll’s on a DaaS system.
Solved2.00K views11th December 2024automation scipt DaaS DLL
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K 9th December 2024 0 Comments
For some of our automation scripts we use some custom created dll's, so functions can be shared over all automation scripts. On an on-premise system, we place these in the Files or the ProtocolScripts folder so the automation scripts can access them. Is there any way to upload these dll's to a DaaS system so we can continue to use the automation scripts that use these dll's?
Michiel Vanthuyne [SLC] [DevOps Advocate] Selected answer as best 11th December 2024
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 10th December 2024 1 Comment
Hi Michiel
As mentioned by Jens, an internal NuGet would be a lot better as it's easier to use and has proper versioning.
If you still want to use a custom DLL, you can place the DLL in the Dlls folder in the Automation Script Solution: Developing Automation scripts as Visual Studio solutions | DataMiner Docs
When publishing via DIS or during package creation from a pipeline/workflow, that DLL will be included in the dmapp package and placed on the DataMiner system.
Michiel Vanthuyne [SLC] [DevOps Advocate] Posted new comment 11th December 2024
Michiel Vanthuyne [SLC] [DevOps Advocate] commented 11th December 2024
Thanks, this worked. I had to create a new project using the template and added some nugets and dll's and everything worked in the end.
