Using custom dll’s on a DaaS system.
Solved1.41K views11th December 2024automation scipt DaaS DLL
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K 9th December 2024 0 Comments
For some of our automation scripts we use some custom created dll’s, so functions can be shared over all automation scripts. On an on-premise system, we place these in the Files or the ProtocolScripts folder so the automation scripts can access them. Is there any way to upload these dll’s to a DaaS system so we can continue to use the automation scripts that use these dll’s?
Michiel Vanthuyne [SLC] [DevOps Advocate] Selected answer as best 11th December 2024
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 10th December 2024 1 Comment
Hi Michiel
As mentioned by Jens, an internal NuGet would be a lot better as it’s easier to use and has proper versioning.
If you still want to use a custom DLL, you can place the DLL in the Dlls folder in the Automation Script Solution: Developing Automation scripts as Visual Studio solutions | DataMiner Docs
When publishing via DIS or during package creation from a pipeline/workflow, that DLL will be included in the dmapp package and placed on the DataMiner system.
Michiel Vanthuyne [SLC] [DevOps Advocate] Posted new comment 11th December 2024
Michiel Vanthuyne [SLC] [DevOps Advocate] commented 11th December 2024
Thanks, this worked. I had to create a new project using the template and added some nugets and dll's and everything worked in the end.
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 9th December 2024 0 Comments
Hi Michiel,
Would it be possible to make use of internal NuGets instead? In that case you can just push your automation scripts, with the NuGets included, to the DaaS system.
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 9th December 2024
