Using Client Test Tools – GetParameterMessage
Solved3.70K views25th November 2021Client Test Tool GetParameter
ryan yahia900 28th October 2021 0 Comments
When using the client test tools using a GetParameterMessage I get this message back for a parameter with the parameter in the xml with these tags:
<Type>read</Type>
            <Interprete>
                <RawType>other</RawType>
                <LengthType>next param</LengthType>
                <Type>string</Type>
            </Interprete>
            <Display>
                <RTDisplay>false</RTDisplay>
            </Display>
            <Measurement>
                <Type>string</Type>
            </Measurement>
        </Param>
Does anyone know what’s causing the error below?
ryan yahia Selected answer as best 25th November 2021
Jens Vandewalle [SLC] [DevOps Advocate]10.09K Posted 28th October 2021 2 Comments
Hi Ryan,
I noticed that your parameter has RTDisplay false. As far as I know the Client Test Tool can only retrieve data for parameters which have RTDisplay true
ryan yahia commented 28th October 2021
Would I be able to retrieve the data for an element with the Display tag set to:
onAppLevel to true
Jens Vandewalle [SLC] [DevOps Advocate] commented 28th October 2021
Only when RTDisplay is equal to true.
The attribute onAppLevel is something that we add to parameters that have RTDisplay equal to true but aren’t part of a table or have no position assigned. The reason behind this is that the DIS Validator complains about parameters with RTDisplay equals to true while it has no position (when used as standalone parameter) or isn’t added to a table (when used as column parameter). In that case we add the onAppLevel equals true attribute so that the DIS Validator will ignore the RTDisplay equals true on this parameter.
For more info: https://help.dataminer.services/development/#t=DataMinerDevelopmentLibrary_Customerpart2CodingGuidelinesCODProtocolLoading_parameters_in_SLElement.htm
-1
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 28th October 2021 2 Comments
Hi Ryan,
Please could you let us know the type of the parameter where are you trying to get the value (single parameter or a column parameter)? Please find below an example for a single parameter:
As Jens mentioned, could it be the case that you are using an incorrect ID?
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 28th October 2021
Thank you for you example. I am trying to get the value of a single parameter
Miguel Obregon [SLC] [DevOps Catalyst] commented 28th October 2021
Hi Ryan,
If this is the case, can you check first if you are pointing to an existing element?
When you right click on an element and select ‘Properties’, you will find the ID in the format DMAID/EID. The first number corresponds to the DMAID and the second number corresponds to the element ID. Can you try with these IDs and let us know if it works?
-1
Gellynck Jens [SLC]2.72K Posted 28th October 2021 1 Comment
One of the cases that causes this exception is when the ParameterId property of the GetParameterMessage does not exist.
ryan yahia Posted new comment 28th October 2021
The parameter does exist, I believe it is a case of it not being a displayed parameter as mentions by Jens Vandewalle
