Users and groups from remote domain through Domain Trust
Solved3.08K views18th July 2023Active Directory Domain trust Users/Groups
Stacey Van Colen [SLC] [DevOps Member]2.75K 1st July 2021 0 Comments
Currently we are able to add users/groups from the customers local domain in the DMS, but we want to also add users/groups from a remote domain.
The local domain is linked to the remote domain via a domain trust, and that is working fine. Users from the remote domain can already login on Windows level. However, we do not find these users in DMS when we try and add these remote users/groups.
Are there some extra configurations that need to be done on the server in order to get these remote users/groups added in the DMS?
Ive Herreman [SLC] [DevOps Enabler]14.80K Posted 1st July 2021 0 Comments
Hi Stacey,
I believe this can be achieved if there is a global catalog available in the multi-domain forest.
You can point DataMiner to this global catalog (which holds the information from all domains in the forest where there is a trust relationship).
