Use case for Splunk or Elasticsearch integration with DataMiner
Solved593 views6th November 2025Elasticsearch SPLUNK
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.86K 21st August 2025 1 Comment
Hi All,
I would like your input on whether we have any general use cases or examples of Splunk or Elasticsearch integration with DataMiner. We have a user who is interested to know if there are existing references or past implementations that they could leverage.
Thank you in advance.
Alberto De Luca [DevOps Enabler] commented 2nd September 2025
I believe I've seen some connectors in the past – whether they can be leveraged as they are, may depend on the version of the target environment – will share some info if I find it from the catalogue
Alberto De Luca [DevOps Enabler]5.36K Posted 2nd September 2025 0 Comments
Jeeva, found these two - in the versions tab you can find more info,
they're both recent integrations from 2025:
https://catalog.dataminer.services/details/ad783a38-693a-4d72-b60a-8d59e4e96068
https://catalog.dataminer.services/details/afe7853b-2784-467c-8cd9-71be79d9ca50
HTH
