Upgrade Path 10.1 to 10.3 is it possible
Solved1.81K views18th September 2023dma upgrade updating
Richard Henderson196 11th September 2023 0 Comments
Currently working on a project to upgrade DMA’s currently running 10.1.  From the documentation the listed upgrade paths are
  • DataMiner 10.0.0/10.0.x to DataMiner 10.2.0/10.2.x
  • DataMiner 10.0.0/10.0.x to DataMiner 10.3.0/10.3.x
  • DataMiner 10.1.0/10.1.x to DataMiner 10.2.0/10.2.x
Is it possible to to upgrade directly form 10.1.0.0-11319-20220112 to 10.3 because its not included in the above. Or is the one of the times when you have to upgrade in sequence?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th September 2023
Simon Raine [SLC] [DevOps Member]2.08K Posted 12th September 2023 0 Comments
Hi Richard,
We always recommend to upgrade in steps between two consecutive minor versions and no more. e.g. 10.1.x – 10.2.x. and so on.
We don’t test all possible upgrade combinations, so our recommendation is based on what we actually test.
Edith Lansens [SLC] [DevOps Member]789 Posted 13th September 2023 0 Comments
Hi Richard,
We have made a subtle revision to the documentation to emphasize that, in addition to our tested upgrade paths, we advise always upgrading to the next major DataMiner version(s) prior to advancing to your preferred version, e.g. from 10.1.x to 10.2.x before proceeding to 10.3.x (preferred version).
Link to the updated documentation page: Upgrade paths | DataMiner Docs
Edith Lansens [SLC] [DevOps Member] Answered question 13th September 2023
