Unable to start the trigger using automation script
Solved1.43K views9th September 2025
Ramesh Rajasekaran [DevOps Advocate]978 4th March 2025 4 Comments
Hello Team,
I have a table with several configurable columns. Whenever an edit is made to these columns, a QAction is triggered based on the parameter ID.
I have created a DataMiner automation script that toggles the default value based on specific logic. It operates as a two-way protocol, where data is fetched from an IP, and any edits made are updated on the server.
I can toggle the default value using engine->element->table->getRow()->setRow(), and I am using IEngine to execute this logic. However, the data is not uploaded to the IP because it does not trigger the QActions associated with the parameter ID. However, when I perform the action through the DataMiner UI, it works as expected.
How to I trigger the event(trigger) while updating the configurable columns using dataminer automation script?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 9th September 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 4th March 2025
Hi Ramesh,
Just curious, is there a reason why you are using SetRow() and not SetParameterByPrimaryKey()?
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.Element.SetParameterByPrimaryKey.html
I was not able to understand what do you mean with 'the data is not updloaded to the IP…'
Ramesh Rajasekaran [DevOps Advocate] commented 4th March 2025
I am using IDmsElement (skyline package) in dataminer automation script to get the element and then the required table. Then I am querying the rows based on the channel name (available on the table). Then I am modifying one of the column data from the queried rows.
Then I use Table.SetRow(primarykey, entire row); to update the column.
This a SNMP protocol, where we listen and get the data from an IP address (Site). And update the data back to the site in case of modification. So its a two way communication protocol.
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Hi Ramesh,
Marieke Goethals [SLC] [DevOps Catalyst] commented 9th September 2025
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 10th March 2025 0 Comments
Hi Ramesh,
I assume that your QAction triggers on write parameter with option row="true" correct?
If you, on the automation script you will have to make the set on that write parameter so it can trigger, you can do that by using the following:
var element = engine.FindElement(...);
element.SetParameterByPrimaryKey(writeParamId, "Key", value);
