Unable to Locate Python Folder After DataAggregator Module Installation
Solved1.23K views2nd April 2024DataAggregator DataAPI python
Mauro Druwel [SLC] [DevOps Advocate]498 28th March 2024 0 Comments
For my project, I’m using the DataAPI along with a Python script. According to the DataMiner documentation, there should be a Python folder, but I can’t find it on the machine.
How can I fix this issue/install Python?
Thanks in advance!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 2nd April 2024
Christine Kapembe [SLC] [DevOps Advocate]1.01K Posted 28th March 2024 1 Comment
Something might have gone wrong during the installation of the Data Aggregator DxM which prevented the installation of python on the affected DMA. I tested this on my DMA and python was installed in version 3.0.1 and 3.0.5. of the Data Aggregator DxM.
Can you please update the Data Aggregator DxM online via the admin page https://admin.dataminer.service, alternatively, we can provide an offline version if you are not able to upgrade via the admin page.
Mauro Druwel [SLC] [DevOps Advocate] commented 28th March 2024
The python folder now exist.
