Unable to get dataminer templates in Visual Studio 2022 for project
Solved3.36K views16th October 2024#automationscript Templates
Apurva Tandon [DevOps Advocate]1.73K 3rd October 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th October 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 16th October 2024 0 Comments
Hi Apurva,
It looks like this problem is too complex to find a solution for it in this Q&A. Could you contact tech support or use the “Send feedback” option in the DIS menu so we can investigate this in depth?
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 3rd October 2024 3 Comments
Hi Apurva
Could you check if you have the latest version of Visual Studio 2022?
Apurva Tandon [DevOps Advocate] Posted new comment 7th October 2024
Apurva Tandon [DevOps Advocate] commented 3rd October 2024
Hi yes, I have latest version
Microsoft Visual Studio Professional 2022 (64-bit) – Current
Version 17.11.4
Michiel Oda [SLC] [DevOps Advocate] commented 4th October 2024
I have the same version and have no troubles. Are you on the latest DIS release (3.1.3)?
Apurva Tandon [DevOps Advocate] commented 7th October 2024
Yes, I am on the latest one
Davor Joleski [DevOps Enabler]743 Posted 8th October 2024 0 Comments
Yes i have thought’s like you the think  is diffrence from 2019 and 2022 ,2019 have templates while creatin on 2022 direct is connected ,so  i was confused too if u can connect everything protocol and scirpt with DIS and display the parameters on Dataminer Cuber you are okej,try this,if don’t try search on Nuget menager the problem you describe the detail on browser or AI that would help i think nuget is general
Davor Joleski [DevOps Enabler] Answered question 8th October 2024
Davor Joleski [DevOps Enabler]743 Posted 7th October 2024 1 Comment
first connect  to the DIS and Domain stuffs then try update maybe that would fix
Apurva Tandon [DevOps Advocate] Posted new comment 8th October 2024
Apurva Tandon [DevOps Advocate] commented 8th October 2024
Yes, I am able to import a protocol and do another stuff when connected to agent, but on creating new fresh project the dataminer templates are not shown and same error on templates update as in image for DIS settings
HI,then try do delete from extension dataminer delete and then again install update all things
and then close VS whole and start again you should have it then that was worked for me i don’t know why should make problem
Hi Davor,
Unfortunately, it didn’t worked
I did remove the dataminer extension and installed again, but on creating new project no dataminer template is shown and in setting on DIS in template it shows the same error as I pasted in the screenshot in my original question.
Davor Joleski [DevOps Enabler]743 Posted 4th October 2024 1 Comment
you can reinstall i had the same problem and its worked for me
Apurva Tandon [DevOps Advocate] Edited comment 7th October 2024
Hi I did reinstall but still its not showing Dataminer templates and I am on Windows 11.
