Trigger an Qaction through Automation
Solved1.37K views19th July 2024
Amer Hodzic [DevOps Member]784 25th June 2024 0 Comments
Hi Dojo Community,
I was wondering if it is possible to trigger a qaction through automation as I tried triggering the trigger but to no avail.
Amer Hodzic [DevOps Member] Selected answer as best 19th July 2024
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 26th June 2024 2 Comments
Hi Amer,
The easiest way to achieve this is by triggering your QAction from a parameter.
You can then set this parameter from your automation script (which will trigger the QAction)
Amer Hodzic [DevOps Member] commented 1st July 2024
The issue is that the Parameter is a context menu and when sending the dependencies as required it still fails
Ive Herreman [SLC] [DevOps Enabler] commented 1st July 2024
Hi Amer,
Although it’s technically possible to trigger the context menu action from an automation script, it’s not considered good practise.
In such cases, it’s better to opt for interApp calls.
More info can be found on this thread:
https://community.dataminer.services/question/automation-script-context-menu/answer/110850/
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 26th June 2024 1 Comment
Hi Amer,
You could set parameter from automation which in turn will trigger QAction.
Hope this helps,
Cheers
Amer Hodzic [DevOps Member] Posted new comment 1st July 2024
