Titan Edge BISS usage
Solved2.57K views29th January 2024Ateme
Marco Di Blasi [DevOps Member]24 23rd October 2023 0 Comments
Hi all
Another question related to the Driver for the Titan Edge, this time I'm testing the BISS.
I see if I need to set the Descr. Mode to BISS, I need to set the Mode before to "CA", if I leave the Mode to "1" or "E" the change on Descr. Mode to BISS not work. Someone can explain to me why?
Anyway after I set the Descr. Mode to BISS, with Mode to "CA", and I try to change the Mode to "E" or "1", Dataminer receives the user input but does not change the value.
What I'm missing?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th January 2024
Thomas Warnez [SLC] [DevOps Advocate]791 Posted 26th January 2024 0 Comments
Hey Marco and Pascal,
I had a look at the connector Ateme Titan Edge. The reason for encountering this issue, is due to the fact that the steps mentioned by Pascal can be done at once via the API. This is currently not possible in the logic implemented in the connector. We currently don't allow multiple sets at once.
There is already a task created to make sure this can be configured via DM.
If you have access to collaboration, you can look at the task in question: https://collaboration.dataminer.services/task/230191
After this, you can update your current version of this connector to support the BISS feature in full.
