Titan Edge BISS usage
Solved1.78K views29th January 2024Ateme
Marco Di Blasi [DevOps Advocate]24 23rd October 2023 0 Comments
Hi all
Another question related to the Driver for the Titan Edge, this time I'm testing the BISS.
I see if I need to set the Descr. Mode to BISS, I need to set the Mode before to "CA", if I leave the Mode to "1" or "E" the change on Descr. Mode to BISS not work. Someone can explain to me why?
Anyway after I set the Descr. Mode to BISS, with Mode to "CA", and I try to change the Mode to "E" or "1", Dataminer receives the user input but does not change the value.
What I'm missing?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th January 2024
Pascal Puzio [DevOps Advocate]20 Posted 23rd October 2023 1 Comment
Hi Marco,
At my side the BISS function not working yet in DM, cannot say how it looks there, I know how it works in Titan Edge.
In Titan Edge software there are 3 steps. ( At the Gateway function).
  1. Select service selection ( None, All or User def)
  2. Descrambling mode (BISS or CAM) if choose BISS, then step 3 will be available.
  3. BISS mode ( BISS-1, BISS-E or BISS-CA).
And so should it be present in DM.
Marco Di Blasi commented 23rd October 2023
Hi Pascal, if I change the BISS parameters from Titan, DM receives the information, but anyway I’m not able to change it correctly.
