Timeout while discovering connection settings or endpoints
Solved5.49K views17th January 2025cube client datamine cube
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K 23rd August 2024 0 Comments
Hello,
We recently installed DataMiner using 10.2 installer but we are unable to access cube :
Connectionsettings :
* type=RemotingConnection;polling=0;zip=true
Endpoints:
http://192.168.1.10:8004/SLNetService
We have installed the URL Rewrite module, restarted IIS but the issue persists.
Cube logging indicates
Message : Login Failed.
Exception : (Code: 0x80040309) Skyline.DataMiner.Net.Exceptions.DataMinerException: Timeout while discovering connection settings or endpoints
at Skyline.DataMiner.Client.Framework.ClientConnection.MakeConnectionInternal(ConnectData data)
at Skyline.DataMiner.Client.Framework.ClientConnection.MakeConnection(Object state)
Https has not been configured in maintenancesettings. Is there anything else we could check to resolve this problem ? Thank you.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 17th January 2025
Seppe Dejonckheere [SLC] [DevOps Enabler]3.05K Posted 9th September 2024 0 Comments
This exception can have multiple root causes so would it be possible to share more of the logging?
If cube is configured to only attempt HTTPS, the lack of HTTPS configuration on DataMiner side could be the cause, but if Cube attempts both HTTP and HTTPS it could be caused by a firewall or the IIS configuration.
Kind regards,
Seppe Dejonckheere [SLC] [DevOps Enabler] Answered question 9th September 2024
