Timeout issue while login to Dataminer
Solved1.73K views26th June 2025Timeout issue
Mohan Ramasamy Veerappan [DevOps Member]216 3rd March 2025 2 Comments
Hi
Could you please anybody help me with the below error in Dataminer which is currently occurring when I try to access the server.
Davor Joleski [DevOps Enabler] commented 3rd March 2025
HI Mohan i had the same issue sometimes but that is so rare ,probably they deploying something or working on that it not be long i think.Do you have this long period or something?
Mohan Ramasamy Veerappan [DevOps Member] commented 3rd March 2025
I have fixed this by providing user permission for web.config file. Earlier user access had been modified by someone due to this it was not working.
Anyway thanks Davor Joleski for your prompt reply 🙂
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 4th March 2025 0 Comments
I get the impression that this question has already been answered in the comments. If this is indeed the case, could you select this answer to indicate that the question can be closed?
Marieke Goethals [SLC] [DevOps Catalyst] Answered question 4th March 2025
