Telestream OTT monitoring integration with DataMiner
Solved3.19K views26th July 2021OTT OTT monitoring Telestream
pramod Gupta [SLC] [DevOps Member]277 25th June 2021 1 Comment
We are currently carrying out a POC of OTT monitoring with Telestream in which the plan also is to get the required driver to integrate this with our Dataminer NOC.
Please let us know what is required in this regard from our side to proceed further.
pramod Gupta [SLC] [DevOps Member] Selected answer as best 26th July 2021
Thomas Gunkel [SLC] [DevOps Enabler] commented 30th June 2021
Hi Pramod. We have a done a demo integration with the Telestream Stream Monitor service. There is also a DMA available under https://telestream.skyline.be which runs a live demo to show how DataMiner can dynamically orchestrate OTT services and as part of that also spin up and configure Telestream ABR probes which are running across multiple cloud providers.
You can find more information, i.e. a Webinar we did together with Telestream on that topic and a demo recording here: https://community.dataminer.services/videos?_sf_s=telestream
Also have a look at this video on Youtube on service-aware confidence monitoring: https://www.youtube.com/watch?v=f0Z581xPrI4
And last but not least we have documented this prove of technology demo in our use case section: https://community.dataminer.services/use-cases?_sf_s=telestream
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 2nd July 2021 0 Comments
Hi Pramod,
We have a driver available that can monitor and control the OTT monitoring solution of Telestream. As mentioned by Thomas, this was developed during a demo integration and in the use case library some screenshots have been added to show some of the pages in the driver: Telestream OTT ABR Stream Monitor - DataMiner Dojo
