Taking values from Spectrum Traces
Solved2.07K views14th July 2023spectrum spectrum analyzer Visio
Yohan Silva [DevOps Enabler]316 12th May 2022 0 Comments
Hello guys,
How can we get the value of the Peak from spectrum trace? I looked on the protocol parameters, and I did not find any place where this value is “saved”; Our goal is getting this value of attenuation – as on the “Test” marker at the image – to show it in a visio drawing.
Kind regards,
Yohan
Ben Vandenberghe [SLC] [DevOps Advocate]9.61K Posted 12th May 2022 0 Comments
Hi Yohan – if you want to perform spectral measurements, and derive variables from that (such as the Peak in your example), you need to create 1) a spectrum script that performs the measurement that you want, and 2) a monitor that executes your spectrum script at regular time intervals.  The result of that will be a new set of variables (e.g. in your case that Peak), and this variable is the same as any other metric (i.e. you can alarm on it, trend it over time, and it is available to be visualized on the UIs.)  This is how you do it: Spectrum analyzer scripts and monitors | DataMiner Docs
Hope that answers your question. If not, don’t hesitate to further elaborate.
Yohan Silva [DevOps Enabler]316 Posted 6th June 2022 0 Comments
Hello, Ben!
Thank you by the support, it was helpful and now the scripts are properly configured to retrieve the amplitude peak. Now, we are trying to show this value in a visio as a parameter, but it is not working… on this attempt the spectrum is being embedded on place of the parameter we want. Do you have any recommendation to how retrieve this information on visio? As I said, it is a variable from spectrum script executed every 30 seconds.
Regards,
Yohan
Yohan Silva [DevOps Enabler] Answered question 6th June 2022
