System center options missing
Solved2.47K views17th July 2023database System Center
Bethany Sheppard20 31st March 2022 0 Comments
In my UI, system center shows only Overview, Search & Indexing, System settings, and Logging. How can I enable the other options e.g. Database?
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 31st March 2022 1 Comment
Hi Bethany,
I suspect that this might be linked to your user rights.
Please have a look at the rights defined on the group linked to your user.
You can find some details on user permissions here.
Toon Casteele [SLC] [DevOps Enabler] commented 31st March 2022
I just want to note that Bethany will need to contact her admin to do this, since she clearly can’t see the Users & Groups :p
