System center options missing
Solved1.94K views17th July 2023database System Center
Bethany Sheppard20 31st March 2022 0 Comments
In my UI, system center shows only Overview, Search & Indexing, System settings, and Logging. How can I enable the other options e.g. Database?
Ive Herreman [SLC] [DevOps Enabler]14.40K Posted 31st March 2022 1 Comment
Hi Bethany,
I suspect that this might be linked to your user rights.
Please have a look at the rights defined on the group linked to your user.
You can find some details on user permissions here.
Toon Casteele [SLC] [DevOps Enabler] commented 31st March 2022
I just want to note that Bethany will need to contact her admin to do this, since she clearly can’t see the Users & Groups :p
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 1st April 2022 0 Comments
Hi Bethany,
You’ll have to contact your system/IT admin for this.
Almost each module in system center has its own permission or set of permissions.
These must be granted to the Security group where you are member of.
Following image shows the difference between administrator (left) and operator with very strict activity (right)
Matthias Declerck [SLC] [DevOps Advocate] Answered question 1st April 2022
