System Center – Clean Up Unused
Solved1.85K views23rd January 2025
Bruno Antonio278 13th August 2024 0 Comments
Hello,
Is there any way to get the list of Protocol not in use from System Center - clean up unused?
Thanks
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 13th August 2024 1 Comment
If I understand correctly you want to export the list of unused protocols to a file? This is not available out of the box but should be doable through an automation script.
Some things you might need:
  • Sending an SLNetMessage
  • new GetInfoMessage(InfoType.Protocols)
  • A list of all elements in your system and their protocol name + version
  • Iterations comparing the list of protocols to the list of elements and their protocols.
  • Some extra filtering (there will be some special protocols in there that are inherent to DataMiner)
  • Download button interactive automation script component
Note: sending SLNetMessages is at your own risk and these messages are subject to change at any point when you upgrade your system.
Bruno Antonio commented 13th August 2024
Hello Toon,
Thanks for your answer. I was looking for an easy (click and collect) solution.
I will go for the automation process.
Thanks
