Switching from Failover with VIP to Failover with shared hostname
Solved693 views15th July 2025agent failover Agent failover configuration dataminer failover Failover
Christine Kapembe [SLC] [DevOps Advocate]1.01K 2nd July 2025 2 Comments
Which procedure should be followed to switch from Failover with VIP to Failover with shared hostname?
Does one of the agent have to be empty or can I simply switch from Failover with VIP to Failover with shared hostname with both agents keeping their data?
Christine Kapembe [SLC] [DevOps Advocate] Selected answer as best 15th July 2025
Chris Glover [DevOps Advocate] commented 2nd July 2025
When we did this, taking the DMA out of Failover mode trashed the companion host. To the point where it was easier to just wipe it and start again
We found the best way to do it was to manually edit the DMS.xml file on each DMA, which worked without having to rebuild anything
Christine Kapembe [SLC] [DevOps Advocate] commented 15th July 2025
Thank you for the tip Chris.
Luís Freitas [SLC] [DevOps Advocate]1.08K Posted 11th July 2025 2 Comments
Hi Christine,
As indicated in the info pop-up within the failover configuration, we recommend decommissioning first when switching the failover type from VIP to shared hostname.
However, we understand this can be very time-consuming, especially when using local Cassandra 1+1, and it also results in the loss of all historical data.
As Chris mentioned, manually editing the DMS.xml file is a valid alternative if you’re familiar with the process and comfortable with shutting down both agents simultaneously.
Luís Freitas [SLC] [DevOps Advocate] Posted new comment 21st July 2025
Christine Kapembe [SLC] [DevOps Advocate] commented 16th July 2025
Hello Luís,
Thank you for your answer.
As a DataMiner user, before I start to configure anything, I first reviewed the documentation and could not find a section that guides users on how to update Failover from VIP to host name. Therefore, I am unaware that there are instructions(popup) in Cube on how to do this.
Luís Freitas [SLC] [DevOps Advocate] commented 21st July 2025
Hi Christine,
The pop-up only provides a brief explanation on how to switch the failover type from a VIP to a shared hostname.
To carry out the change, please follow these steps:
First, go to https://docs.dataminer.services/dataminer/Administrator_guide/Failover/Ending_a_Failover_configuration.html.
Then, https://docs.dataminer.services/dataminer/Administrator_guide/Failover/Configuring_Failover/Failover_configuration_in_Cube.html?tabs=tabid-1 and follow the instructions for the hostname configuration path.
