Stream Viewer: Element not known yet
Solved2.24K views14th July 2023SNMP stream viewer
Alex Johnson [SLC] [DevOps Advocate]921 25th April 2022 0 Comments
When testing snmpv1 and snmpv2, I've been occasionally getting a strange streamviewer message:
This happens when uploading a new protocol (eg: copying and pasting) where the previous protocol was snmpv1 and the new one is snmpv2. The funny thing is, when I switch the version back to a previously released version that uses snmpv1 and then back to the version i'm working on, the stream viewer error goes away.
The customer also reported seeing this error on a few elements when setting an snmpv2 version to production from a previous version that uses snmpv1.
What does this error mean? Is it a software issue? We are on DM 10.2.3.0-11516.
Wouter Demuynck [SLC] [DevOps Advocate]7.08K Posted 26th April 2022 0 Comments
As far as I can see, the error message pops up when a protocol wants to do an SNMP Get and the SLSNMPManager process doesn't know about the element. It will then retry this every second.
I would guess that your case could be a software issue/race condition when switching drivers between SNMP versions, leaving a mismatch between processes.
Another workaround might also be to restart the elements once more after changing the driver.
