SRM – What are the differences between “Partial” and “On-hold” booking states?
Solved1.96K views15th July 2020SRM
6
Bruno Dias [SLC] [DevOps Member]2.39K 15th July 2020 0 Comments
I was wondering what are the differences between these two booking states – “Partial” and “On-hold”. Specially about the resource assignment.
Bruno Dias [SLC] [DevOps Member] Selected answer as best 15th July 2020
Gelber Mahecha [SLC] [DevOps Enabler]2.03K Posted 15th July 2020 0 Comments
A Partial booking has incomplete resources and therefore, can’t be executed (no automation). It could be incomplete because the user unassigned a resource, or a resource can no longer be used (i.e., in maintenance), and it has been acknowledged without solving the situation.
On the other hand, an On-hold booking has all the resources valid, but the user has put it in on-hold for one reason or another; the resources are reserved, but the automation won’t happen.
