SRM – Simple Resources (not element based)
Solved3.25K views4th July 2023service defintion SRM srm function SRM resources
Jamie Stutz [SLC] [DevOps Member]1.18K 10th June 2023 1 Comment
I get the impression from watching some of the videos that it is possible to create Resources for Bookings that are not based on elements. For ex., to create a list of IP addresses or a list of engineers that might be assigned to a booking.
Creating the resources are easy enough, but the part I’m missing is, how do you get the resources to show up when creating a booking? Since these resources are not coming from a protocol, I’m not sure how to create a Function. And, without the Function, I’m not sure how to get them into a Service Definition.
I’m probably missing something simple, so any push in the right direction would be appreciated. Thanks!
Steven Soenens [SLC] [DevOps Member] commented 13th June 2023
Hi Jamie, if your use case is to create pools and resource instances (one-by-one or in bulk) such as people, then we have a good blue print application that does exactly that on ziinedev : https://ziinedev.skyline.be/app/06951cc4-5695-4f6c-a49b-55582d72f611/page/Home
In this app, you have a nice example of how DataMiner users can create objects such as organizations, teams and people. In addtion, teams can be made ‘bookable’ as an optional selection. The latter will automatically create bookable resources in the background, and add capacity and capabilities to those (e.g. ‘Team Expertises’ will automatically translate into ‘SRM capabilities’ to all resources in the pool)
Adding to that, we are generalizing the resource administration in a new app, since there is so many use cases where DM users need a simple way to create resources in bulk. You can use this for any ‘unmanaged resource’ (i.e. resource not linked to a specific element, VF, etc), or resources linked to an element (the latter is on the backlog coming available in 1-2 weeks from now). The app is not in an MVP state yet, but could be used in case you need something almost off the shelf quickly
I’ll be happy to walk you through all of that ! Let me know !
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 12th June 2023 3 Comments
Hi Jamie,
You can use resource pool inheritance. However, what you want to book needs to be something related to a function resource you add in your booking.
Example : when you book an IP Encoder function resource, you will typically also define a profile parameter, ‘IP Address’, that will be applied on the Encoder resource at start time of the booking. To avoid conflict, the IP Address needs to be selected from a pool of IP resources. Therefore, the ‘IP Address’ profile parameter will be linked to that pool, and the SRM Framework will book an item from the pool when booking the IP Encoder function resource.
More info on how to configure it can be found in Docs
In case you have a different use case in mind and Pool Inheritance would not be an option, please provide more details so that alternative can be suggested.
Jamie Stutz [SLC] [DevOps Member] commented 12th June 2023
Thanks Emmanuel! I am not familiar with this, but will read about it in the docs and let you know if I have any clarification on the use case after that.
Jamie Stutz [SLC] [DevOps Member] commented 13th June 2023
Hi Emmanuel… I checked this out and see how this can be used for booking IP addresses.
The other use case I was considering was if I created a Resource Pool called “SAT.Engineers” and in that group I manually created “people resources” so I could track a list of people who can be booked to support a booking. The challenge is: I can manually create resources, but, since they are not linked to an element, I can’t select a Function for them. Without the function, I can’t get a node for the engineers in the Service Definition. Unless there’s something I’m missing, I guess easiest solution would be to use something like the Skyline Generic Source element, but for people. That way we have a Protocol and can create a Functions.XML file.
Emmanuel Dal [SLC] [DevOps Member] commented 13th June 2023
Hi Jamie,
Using Resource Scheduling feature, you can book any type of resources. It is not required to create an Element and a function definition.
In case you want to test this, get cloud connected and deploy the SRM User cases Demo package: https://catalog.dataminer.services/catalog/4648
After deployment, you will have a Visual showing camera resources. Just adjust the the Visio drawing so that the InitVar contains following value : YAxisResources:pool=_name_of_your_pool_. Then close and re-open the view and you’ll be able to book non-function resources part of the pool.
In case you want to go one step further and extend bookings based on service definition, then you’ll have to create a custom booking front-end ( which is always better for user experience ).
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 10th June 2023 2 Comments
Hi Jamie – not sure, but isn’t it simply a matter of creating a resource pool in the Resource Manager, and add the resources in there (without linking those to a function or element)?  In that case you have what is called a virtual resource (not associated with a real element or part thereof).  An example of that would be SDMN.Multicast Adress on Ziine.
Jamie Stutz [SLC] [DevOps Member] Posted new comment 10th June 2023
Ben Vandenberghe [SLC] [DevOps Advocate] commented 10th June 2023
I see now, you are not sure how to specific that you need one of those resources for a specific type of booking (i.e. how to make it part of your service definition).
Jamie Stutz [SLC] [DevOps Member] commented 10th June 2023
Getting it in the Service Definition so it is available for selection at booking time is the part that’s tripping me up. I’ll take a look at the Ziine demo you referenced to see if that helps me figure it out. Thanks!
Jens Vandewalle [SLC] [DevOps Advocate]10.09K Posted 12th June 2023 3 Comments
Hi Jamie,
I use this on Ziine for the SDMN demo. There I have an encoder application that needs to get an IP assigned from a pool of available multicast addresses. In below capture you can see how I’ve done this.
Note that you only need to do this when you work with the default booking scripts that comes with the SRM framework package. In case of a custom (silent) booking script you’ll have to add logic in the script itself.
Jens Vandewalle [SLC] [DevOps Advocate] Posted new comment 13th June 2023
Thanks Jens! I will take a look.
Hi Jens… thanks again for this! I was thinking about booking IP addresses differently, but this makes perfect sense.
Jens Vandewalle [SLC] [DevOps Advocate] commented 13th June 2023
Hi Jamie, I’m sure that other teams in Skyline have used different approaches. This one works in my case when I use the default booking wizard script.
