SRM – Schedule Resources when Element is in redundancy group
Solved2.19K views5th July 2023redundancy group SRM
Stacey Van Colen [SLC] [DevOps Member]2.75K 28th April 2023 0 Comments
I have the following Element Redundancy Group:
  • 1 Main Element
  • 1 Failover Element
We want to create resources on the Virtual Element, and book these resources.
Is this supported? And when the Virtual Element switches from Main to Backup, will the resource then also move along and everything work okay?
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 28th April 2023 0 Comments
Hi Stacey,
Function resources can't be generated from a virtual element.
Alternative is to define a regular resource and link it to the Virtual Element of your Redundancy Group. That way you'll be able to schedule your resource ( Resource Scheduling) ; however , you won't be able to use the standard Profile-Load scripting feature.
