Spectrum Analyzers: Alternative ways of detecting if an element card is open in DataMiner Cube
Solved1.84K views16th May 2024spectrum analyzer
Chian Hao Aw [SLC] [DevOps Member]650 29th April 2024 1 Comment
Is it possible for a protocol to detect if an element card is open in DataMiner Cube?
To give some context, I am creating a spectrum analyzer protocol that communicates like a smart-serial device. I would like to disable the polling/retrieval/processing of data if the element card is not open such that it doesn't run in the background, such that it can support multiple sessions.
Is there a reserved parameter or a method to ensure this?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th May 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 29th April 2024
Hi Chian,
Maybe you could change the settings in the standby mode?
https://docs.dataminer.services/user-guide/Advanced_Modules/Spectrum_Analysis/Working_with_Spectrum_Analyzer_elements/Viewing_spectrum_analyzer_traces.html?q=spectrumanalyzersession#sharing-spectrum-sessions
Another option is to use shared sessions:
Do these options fit your use case?
Tom Waterbley [SLC] [DevOps Enabler]10.21K Posted 29th April 2024 2 Comments
Hi Chian,
Every element has a general parameter "[Clients connected]" (ID 65029) which has value Yes=1 when a client is connected, or value No=0 when no clients are connected. Maybe you could use this in your connector.
https://docs.dataminer.services/develop/devguide/Connector/ReservedIDsElementControlProtocol.html
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 29th April 2024
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 29th April 2024
I think this is less relevant for Spectrum integrations. our Visual overview supports features to show inline trace graphs , this will accept certain “Spectrum monitors” as arguments. In return the spectrum element will need to make sure it can process and request new trace data based on this. So if we block communication based on this 65029 parameter, I don’t think the end goal will be met…
Tom Waterbley [SLC] [DevOps Enabler] commented 29th April 2024
Hi Thijs. I thought the problem was that DataMiner was interfering with users that are working directly with the spectrum analyzer, or another external application. That was not completely clear from the question. But if that is not the case my answer is indeed not really relevant.
