Skyline Taskbar Utility – Upgrade does not keep credentials
Solved2.07K views21st January 2021SLTaskbarUtility
Miguel Obregon [SLC] [DevOps Catalyst]22.42K 20th January 2021 0 Comments
We noticed that every time that we update the Skyline Taskbar Utility (that comes with a DataMiner upgrade), the credentials previously stored in the 'slnet' tab are removed:
For this test we upgraded from 10.1.1.0-9814 to 10.1.1.0-9843. However we noticed this behavior already in previous Feature Release versions.
Please could you let us know if this is expected behavior?
Thanks!
Miguel Obregon [SLC] [DevOps Catalyst] Selected answer as best 21st January 2021
Brent [SLC]2.22K Posted 20th January 2021 3 Comments
Hi Miguel,
From a quick test it seemed that this behaviour changed between 10.0.5.0 and 10.0.6.0, in 10.0.6.0 there is a default ApplicationSettings.xml included in the package which was not present before. So upgrading from 10.0.4.0 to 10.0.5.0 would keep the settings, any further upgrades removed it.
There does not seem to be any indication as to why this is changed, so I assume it is unintentional.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 21st January 2021
So this will also be the reason why the configs were no longer visible in the Skyline Taskbar Utility after an upgrade.
Task created to roll this back.
Brent [SLC] commented 21st January 2021
Everything in the ApplicationSettings.xml would be reverted to the default settings, so yes, this would also disable configs.
Miguel Obregon [SLC] [DevOps Catalyst] commented 21st January 2021
Thanks for the quick answer!
