Setting up SLLogCollector for CPU
Solved1.27K views16th January 2025SLLogCollector
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K 29th November 2024 0 Comments
Hello,
I want to capture logs + memory dumps of a process when the CPU usage of the process crosses say 30%.
Is there a way to setup SLLogCollector for the above requirement ? Or are there other ways to achieve this ?
Thank you.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 16th January 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 29th November 2024 2 Comments
Hi Arun,
I noticed that you can run the SLLogCollector via command line. You could use the Microsoft Platform element to achieve this:
  • Create a correlation rule that will be triggered when an alarm assigned to the 'Total Processor Load' is higher than x%
  • The correlation rule will trigger an automation script that will execute the SLLogCollector via command line
Hope it helps.
Martin Vrzba [DevOps Advocate] commented 29th November 2024
Hi Miguel,
Could you please provide an example with necessary arguments for the SLLogCollector executable to run autonomously?
Thank you.
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 16th January 2025
Hi Martin,
I have a script that can trigger log collector on demand. You just need to create a correlation rule that will trigger the script when an event occurs (say if an alarm occurs).
Do let me know if you still need the script.
